cy8ckit-002
I am having a hard time to communicate to my device, using Cypress CY8CKIT-002 (PSoC MiniProg3 Program and Debug Kit).
I already have VIs so that I can use the debug kit through labview. Attached is the sample code that I worked with.
Anyone can help me?
(3,465 Views)
What, specifically is the trouble that you're having?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,448 Views)
Im trying to communicate to my device. And it seems like I can't go into the device. I've already searched the appropriate device address, but still nothing.
I tried to use the Cypress' self power, nothing happens. Even powering the debug kit externally nothing changes.
I'm not quite sure if i have the wrong settings or it's just the code itself.
(3,439 Views)
I'm trying to write something on my device through the debug kit, then read it if it successfully writes in.
(3,438 Views)
Is there any sort of response that you can see in the hardware when you write to the board? LED turns on or blinks, anything like that?
Mike...
LabVIEW Champion
(3,435 Views)
When I started to run the VI, the debug kit blinks for a while, then that's it. I thought the write was successful. But I'm not quite sure if it does succeed, because I can't read anything.
BTW, the hardware that I'm writing in is a power supply with EEPROM, which I need to write some specific data on it.
(3,395 Views)
