customizing enumerator control
Hi ALL
I want to customize my enumerator control, I just want my control to have the Up-Down button on the right of the control and not on the left. I customized it but when I resize the control it move the up-down arrows not in the right way. Is this a bug? I don't have the same behaviour if I customize on the same way a number control! Am I making some mistake?
Thanks to all.
Ricky
Italian Developer engineer
www.www.selt-sistemi.com
(2,898 Views)
Accepted by topic author g_Ricky
Just to let you to know that I'm having this behaviour just on labview 2010sp1 and not in a newer version so, I think we can assert that it was a bug, and we can close the discussion.
Ricky
(2,883 Views)
I was able to confirm suspicious behaviour when I used the silver enum.  The standard enum looks like it does not exhibit this issue so perhaps you might try that one as a work around.
(2,878 Views)
Dear all,
I tried to customize my enum control with LabVIEW 2012 and I found no trouble. I attached you the customized enum control. I'll try to customize it in LabVIEW 2010 in order to verify if there is a bug in that version.
Have a great day.
Cheers
Cla_Cup
NI Italy
Application Engineering Dept.
(2,837 Views)
