customizing an XY graph
I want to customize an XY graph by having three y-axes, one on the right and two on the left, one above the other. I've used the customize control function to increase the height of the plot area and move the left plot scales into position. Both scales are the same height, however I would like the lower one to be half the height of the upper, but the scale heights don't seem to be adjustable. Is this possible ? I'm currently using two graphs but this would be more elegant. Any help or suggestions would be really appreciated. Please see attachment
Sbloomfield
(2,691 Views)
The only way to do what you want is to use two graphs--at least XY plots. But you might want to check-out some of the plotting examples that ship with LV which make use of the picture indicator. I have use it many times to generate barcharts that don't behave the way LV's standard ones do.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,691 Views)
