customized control
When you customize a control and import a picture from the clipboard, why can't you remove it later?
Message 1 of 11
(6,701 Views)
You often can, you may have to click the little tweezer or wrench to switch editing mode.
Message 2 of 11
(6,678 Views)
Thanks for the reply. I have changed to customize (tweezer icon) but still cannot delete. Any other suggestions?
Message 3 of 11
(6,665 Views)
Can you attach it here? I am using LV 2012, so you may have to go to File >> Save for previous version... so that I can view it.
Message 4 of 11
(6,661 Views)
Sometimes depending on the control, be it a button, you have to ensure you are in the right mode.  By that i mean either the on or off.
-Matt
Message 5 of 11
(6,637 Views)
Thanks, I checked that. Not the issue, but I appreciate the help and suggestion.
Message 6 of 11
(6,599 Views)
OK, let me do that on the development computer and then I will attach in another reply. Thanks for the help!
Message 7 of 11
(6,598 Views)
Here is an example VI attached gregoryj
Message 8 of 11
(6,536 Views)
Sorry, here is this LV 2012 version of the VI
Message 9 of 11
(6,532 Views)
you cant delete image if you replace it with one of that control picture Item
in this case you could just replace your image with other icon or image and cant delete because these image represent  the control modes
and you can not delete one of the control modes
Message 10 of 11
(6,529 Views)
