customize multiple Y scales in one wave graph
  I am trying to show two channels in the same waveform graph but with seperate Y scales. And I want to customize the two Y scales independently using property nodes. But I found under the waveform graph property node there is only one Y scale.
  Does anyone have the experience to customize them independently using property nodes?
XP\LabVIEW 2011
(2,764 Views)
Accepted by topic author Exia
Use the property "Active Y Scale" to select the scale you want to act upon.
Set Active Y scale to 0 (the first Y scale), then set all the properties as you wish for that 1st Y scalethen set Active Y scale to 1 (the second Y scale) and again set all the properties you wish for that 2nd Y scale.
Hope this helps
Epictetus
Antoine Chalons
(2,762 Views)
It worked perfectly. Thank you very much.
(2,750 Views)
