custom waveform
Does LV8 have anyway of generating a custom waveform??  A guess it would be TTL.
I'm trying to generate a custom bit pattern.
The specs are:
A Logic 1 is 2 microsecs long with an amp of +5 vdc.  The rise & fall times ( which are critical!!) is no more than 0.6 microsecs.
A Logic 0 is 2 microsecs long with an amp of -5 vdc.  The rise & fall times ( which are critical!!) is no more than 0.6 microsecs.
Between a logic 1 and a logic 0 is about 2 microsecs.
Can you do this with an array of values?? Multiplying two waveforms together??  Is there  a shipping example just like this/
Clint
(3,330 Views)
Clint,
LabVIEW can specify the timing, but as software, it cannot generate the voltages. The voltages you list are NOT TTL! Nor are they any standard logic family that I have heard of.
Your specification is unclear on one point: You specify rise and fall times of 0.6 us and a time between logic 1 and logic 0 of 2 us. This seems inconsistent. What is the signal doing for the 1.4 us difference?
If your signal must swing from +5 V to -5 V in 0.6 us, then you will need an amplifier with a slew rate > 16.6 V/us. This is fast but many such amplifiers exist. How much current is required statically and dynamically?
Lynn
(3,325 Views)
Lynn,
I'm using a DAQ Card to actually generate the signal ( PXI 6259).
I would just like a VI that allows me to vary a signal's rise and fall times as well as make the signal bipolar.  I also think I may need to have control over the duty cycle.  I'm thinking this because I want to vary the time between the logic 1 occurance and a logic 0 or another logic 1.
Clint
(3,315 Views)
Hi Clint,
Your board supports what you want to do. you have a slew rate of 20V/us which will accomplish the 10V swing in .5us. As far as changing the rise/fall time, I don't believe you can control that unless you build it into your signal. For example, if instead of writing 0V then +5V (rise time = .25us) you can write 0V then 2.5V then 5V at the same sampling rate to double your rise time. As for the rest of it, I suggest you create your signal in an array and write it with hardware timing.
Mark
Sappster
(3,283 Views)
