curve fitting
Hello, it is a student from istanbul. I have a problem about curve fitting. I have two arrays with five elements in each and one of them decsribes the x axiz and the other one describes y. so as you can guess, i have five different points and i want to apply lineer fit to them. I almost checked all the examples in labview library but unfortunately havent found a solution for my application. I hope someone has an advice about it.
King Regards,
Emin Ekşi
(3,856 Views)
Hi!
   Have you looked under the function palette --> Analyze --> Mathematics --> curve fitting ?   I actually don't know if it is a separate plugin, I have Developer suite 7.1, and I have these functions on my function palette.
   Anyway, if you don't have it, you'll have to implement manually a linear fit or interpolation from the formula.
graziano
(3,852 Views)
The curve fitting functions are not part of the base package of LabVIEW.
Curve Fitting VIs help page
(3,850 Views)
   if you don't have it, you may give a look at "numerical recipes in C", ch 15-2.  It is a good starting point for implementing algorithms, without going too deep in theory behind them.  the book is freely available online.
graziano
(3,846 Views)
Also there is a new curve fitting white paper on ni.com, talking about some curve fitting concept.
http://zone.ni.com/devzone/cda/tut/p/id/6954
Hope this helps.
(3,763 Views)
Nice WP!
(3,756 Views)
