cursor
Hi
I want to show the cursor on the XY graph,but I want the reading of the cursor can display on the graph or indicator also can.I do not want to show in the legend box.how to set
another question is I just want horizontal cursor to display y-axis value,i do not want the x-axis value, how to remove in the legend box?
thx in advance
(2,825 Views)
If you right click the XY graph, go to the visible items and uncheck cursor legend. To display the values of the cursor using an indicator, go to your block diagram and right click the XY graph and goto Ceate--> Property Node --> Cursor -->Cursor Postion--> Cursor X. Now drag the blue drag block and it should display the y position as well. Then you can wire up indicators to it.
Hope this helps!Smiley Happy
(2,675 Views)
You can then right click the X postion property and change it to write and set it to a very high number effectively removing it from view.
(2,662 Views)
