cursor style question
Hi, I set the cursor style of XY Graph is a cross cursor, but it shows a horizontal line only.
I tried to pull another line from the borders of the Graph, but I can't find and drag another line.
But I open a new VI, and place a new XY graph, set the cross cursor, it works, same setting.
(3,013 Views)
If you have a cross cursor and only see the horizontal line, then I'm assuming you're x coordiante of the cursor is outside the range of your window.  If you show the cursor legend (visible items->Cursor Legend) you should be able to confirm the x,y cooridante of the cursor.
Tim Elsey
Certified LabVIEW Architect
(3,008 Views)
Thanks, you are right.  Since I use time as x coordinate, I found the x coordinate of cursor is out of display range.
It seems the x coordinate of the cursor is the location of display for last time. It can't update automatically accroding to the new X range ?
Or I have to use property node to reset it?
(3,002 Views)
Accepted by topic author concorpoly
I haven't used too many cursors, but I assume you have to move the cursor either by dragging it or setting its value with a property node.
Tim Elsey
(2,997 Views)
