current
Is there a cheap way of measuring current with LABVIEW?
Message 1 of 10
(5,013 Views)
It depends...
How much current? Can you insert a shunt resistor in the circuit, preferably with one end grounded? What frequency or waveform does the current have? How do you define cheap?
Lynn
Message 2 of 10
(5,005 Views)
Sure how does $36 sound?  If you have a spare COM port or a USB to serial adapter you can use these drivers and read down to the microamp level a few times a second.  Also does AC current, resistence VDC, VAC and a bunch of other features.
Message 3 of 10
(4,999 Views)
How would I be able to get the multimeter to output the current with a labVIEW program and a USB-6211?
Message 4 of 10
(4,943 Views)
You need an RS-232 port in place of the USB-6211.
Lynn
Message 5 of 10
(4,940 Views)
Since when does using a 6211 become a requirement?  That seems like important information that should have been mentioned in the first post.
Message 6 of 10
(4,921 Views)
https://forums.ni.com/t5/Example-Code/Measure-Current-Using-NI-myDAQ/ta-p/3996490
Would the labVIEW program used in on this page work when using the rs232 cable and multimeter?
Message 7 of 10
(4,918 Views)
You obviously know nothing about LabVIEW, instruments, or DAQ devices. That link you posted has nothing to do with a serial connection to a meter. If, In fact, you actually have a 6211, use that with a shunt resistor. If you are saying you actually have a myDAQ, then use it.
Message 8 of 10
(4,899 Views)
This is a dangerous, potentially costly combination.  Maybe the OP should find someone who knows what they are doing.  Do this wrong and things get blown up.
Bill
CLD
(Mid-Level minion.)
Message 9 of 10
(4,887 Views)
Nothing like using a high side current shunt on a 60V line to let the smoke out of your DAQ card.
Read this white paper: Measuring Current with an Analog Voltage Input
Message 10 of 10
(4,823 Views)
