csv,2D
How about this? In addition to this, I want to synchronize AI and AO.
sheep
Message 21 of 31
(360 Views)
I want to synchronize AI and AO. In that case, is it possible to synchronize them with something like DAQ.mx triggering? If it is possible, I would like to know how to do it. If it is not possible, I would like to know if it would work with a trigger.
sheep
Message 22 of 31
(354 Views)
Hi nana,
again you failed in downconverting the VIs to LV2019!
Only the lvproj file is converted, all the VIs/CTLs are for LV2025…
Message 23 of 31
(342 Views)
How about this? If this doesn't work, I think I might be doing it wrong.
sheep
Message 24 of 31
(339 Views)
Hi nana,
now you attached the converted VIs…
Why don't you cleanup your code? Like this:
It would really help US when YOU would use English labels…
Have you considered to learn from all those DAQmx example VIs in the example finder?
There are examples that explain how the sync DAQmx task, either by starting them (nearly) at the same time or by using a DAQmx trigger option!
Message 25 of 31
(333 Views)
I read it many times and tried it, but it all didn't work. I may not have the ability to understand, but I am completely stuck and unable to move.
sheep
Message 26 of 31
(324 Views)
Sorry for the sudden question. Which feature is best to use if I want to synchronize? Even when I used triggers, it wouldn't move from a value of 0 at all. I might be doing it wrong, but I can't figure it out on my own. Please, could you help me?
sheep
Message 27 of 31
(316 Views)
Hi nana,
@nananass wrote:
Which feature is best to use if I want to sync? I’ve tried using a trigger, but it’s not working well. Could you please advise me?
What have you tried and what is "not working well"?
When your timing requirements are low then you can just start both task "at the same time".
Otherwise you might use the AO start signal as a trigger for your AI task…
Message 28 of 31
(306 Views)
Do you have synch-problems now? DAQ-triggering shouldn't be needed at those slow speeds. Try this:
Qestit Systems
Certified-LabVIEW-Developer
Message 29 of 31
(278 Views)
Hi,山前
The value that was supposed to come last is not appearing, and it stops one step before. I think the cause is that the output value is coming out one step late compared to the seconds value. I suspect that the AO is read first, and then when writing with AI, a misalignment occurs. Therefore, I want to synchronize AO and AI so that they start at the same timing. However, I couldn't achieve this using several sample clock methods or timing adjustments, so I would like your guidance.
sheep
Message 30 of 31
(245 Views)
