crio serial port errors - overrun
I have a crio 9023.  I use modbus on the serial port to communicate with an external device.  I'm getting serial port error (-1073807252) described below.  It looks to me that the frequency of this error is directly related to cRIO total usage.... Unfortunately even at 40% (where my program normally runs) the error occurs, and then when I up it to 60% it happens more.
Does this make sense tying this to crio usage?  or is there something else I can do?
Error -1073807252 occurred at VISA Read in MB Serial Receive.vi:3->MB Serial Master Query.vi:2->MB Serial Master Query Read Holding Registers (poly).vi->PLC Main Old Modbus.vi->Stirling Main.vi
Possible reason(s):
VISA:  (Hex 0xBFFF006C) An overrun error occurred during transfer. A character was not read from the hardware before the next character arrived.
(2,847 Views)
You need to make sure you give the serial port enough priority so that the buffer never fills up completely.
Machine Vision, Robotics, Embedded Systems, Surveillance
www.movimed.com - Custom Imaging Solutions
(2,840 Views)
Priority of the timed loop?  Or is there a different setting for the serial port?
(2,837 Views)
