crio analog input problem
Hello
I'm using crio with AO NI9263 and AI N9239 modules and trying to measure on AI what I'm sending on AO. The problem is that if I use FPGA I don't get any results. I've tested the modules using Scan Interface mode and there AO+AI works perfectly well. Does anyone know what can cause the problem?
Regards
Mikolaj
Message 1 of 9
(4,054 Views)
Hi Mikolaj,
where do you have problems? Do you still use the Scan Interface mode or did you write your own FPGA vi?
Mike
Message 2 of 9
(4,048 Views)
Hi Mike
I have written an extremely simple fpga vi. I write to AO and read from AI. No matter what I write to AO on AI I always get 0 (zero). Simmilar vi executed in Scan Interface mode works fine.
Mikolaj
Message Edited by souske on 09-09-2008 11:55 AM
Message 3 of 9
(4,044 Views)
Hi Miloaj,
did you check you modules seperatly? Can you output something? Did you check if you have selected the correct mode? Did you download all functions to the fpga?
Mike
Message 4 of 9
(4,040 Views)
Hi Mike
Yes to all  Smiley Happy I even checked AO with a multimeter to make sure that something goes out.
Mikolaj
Message 5 of 9
(4,026 Views)
Hi Mikolaj,
so you have only problems with reading the AI?
Mike
Message 6 of 9
(4,024 Views)
Yes.
Mikolaj
Message 7 of 9
(4,010 Views)
I'd bet the problem you are running into is that you are not writing to the digital Start channel for the 9239, which is only available on the FPGA. Note that the FPGA I/O Node for the 9239 AI channels is self-timed (based on the module's data rate configured).
The programming experience for the 9239 is similar to the 9233. Check this other thread where someone was running into the same problem
http://forums.ni.com/ni/board/message?board.id=280&message.id=4432&query.id=127789#M4432
Hope this helps.
Message 8 of 9
(3,992 Views)
Thanks! That solved the problem. Examples for hardware are also a very nice thing. I completely forgot about them.
Regards
Mikolaj
Message 9 of 9
(3,980 Views)
