creating waveform chart
Hello all, I am facing an issue while I am trying to have simple waveform chart due to mismatching with current time. sometimes the time at x-axis is correct but not always. what would be the reason for that please.
(837 Views)
Accepted by topic author Omar-Abdelhameed
Your x axis is formatted in absolute time.
Before the loop, you can use a property node where you wire the current time to x0 and the loop time to dx.
If you want to format the x axis in relative time, x0=0.
(819 Views)
