creating subroutines for multiple event structures and common stop button
Hi Guys,
I wonder if there is a better way of designing algorithm in below scenerio than repeating similar technique for every event structure.
Please find attached vi where I designed code for one boolean (D). I want to design similar code for all other bolleans. (In this design code, picture is displayed when mouse is hovered over D). For other booleans,(A,B,C,E,F) I have obviously other pictures. Can we have some sort of subroutines for remaining booleans and a single stop button for whole application.
Many thanks in advance for your support.
(3,274 Views)
Accepted by topic author kwaris
sorry (forgot to add vi) please find attached.
(3,272 Views)
if you save your code in 8.6 I will take a look at it
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(3,259 Views)
there is something called as "Subvi" in LabVIEW which can be used for common operation.
I can not see your code since i have 8.5 installed on my machine.
However here is an example for you to undertsand the same.
In this vi, i have used the select to perform the operation and you can use the same to specify the image path while hovering over.
Go through the LabVIEW help (Help->Search LabVIEW help and also the examples) for more information on how to use the subvi's tips and tricks
Message Edited by Guruthilak on 02-01-2010 12:28 PM
Regards
Guru (CLA)
(3,257 Views)
As far as I can understand, you need design pattern like this:
You can choose right image by using appropriate index.
Hope it helps,
Andrey.
(3,229 Views)
