creating custom error message
I'm a newbie as well and I'm being migrated from LabWindows to LabVIEW. I'm trying to use the "General Error Handler" VI to handle some problems if there is a problem on the GPIB Bus. I'm a bit confused and befuddled with it. I need to supply my own message to the technician about the set up and what needs to be done if there is an error on the GPIB bus. How does one set that up?
I've included a sample VI so you can get an idea how I am setting this up.
Steve
(2,784 Views)
Hey,
You can build your own error codes under Tools>Advanced>Edit Error Codes
BR, Ch.
(2,772 Views)
