creating activeX dll in visual basic 6
Hi i was wondering if anyone could give me some tips on how to compile a visual basic 6 program so that an activeX dll file can be called by LabView to start my program.
When i configure the Call Library Function node to use the dll file it only allows me to use the following under the 'Function Name' drop down list:
1)DllCanUnloadNow
2)DllGetClassObject
3)DllRegisterServer
4)DllUnregisterServer
My Library Path is the dll created by my VB program which contains a module (.bas file) with my code and a .cls file.
I am new to VB and have been using the Microsoft Developement Network online help to create my programs for VB.  Any help would be great.  Thanks!
teky
(4,027 Views)
You must be new to LabVIEW as well. You do not use the Call Library Function Node for ActiveX. You use the functions on the Commuication>ActiveX palette. These will open an ActiveX object and give access to the properties and methods in your ActiveX control.
(4,020 Views)
Is it possible to do the same thing using LabView's System Exec vi to call an ActiveX exe file created in Visual Basic?
I do not need to pass any parameters into the VB program, nor do i need any output.  Just a simple execution of the program is what I desire.
Message Edited by teky on 08-08-2006 02:45 PM
(4,016 Views)
You can use the system exec to call any executable.
(4,012 Views)
That is great, thanks.
(4,008 Views)
