creating a readme file
I´m distributing a new version of the program I´ve develope, and I´m trying to make appear a "readme file" once the installation program is finished, warning the users from the modified features. So far, I guess it should be somehow introduced in the "Advanced..." installer settings of the "aplication Builder" tool.
How should I call the file or make the executable? And what about the "Command line arguments" field?
Thanks in advance.
Message 1 of 12
(4,628 Views)
for Command Line Arguments there are several KBs on web:
http://zone.ni.com/reference/en-XX/help/371361A-01/lvhowto/launchingvifromcommandline/
http://zone.ni.com/reference/en-XX/help/371361A-01/lvprop/app_command_line_args/
On your PC is a great example: Open Ni Example Finder, got to Search tab and type "command".
The first example, it's called "CommandLine.vi" is the right one.
In LV8 you have the option to define a Readme file in the installer properties-Product Information
ThSa
Message 2 of 12
(4,613 Views)
Try to run a batch file containing the following line:
notepad readme.txt
This should work, unless there are directory issues.
Paolo
Paolo
Message 3 of 12
(4,606 Views)
Can u please give a bit more information about this batch file?
Message 4 of 12
(4,591 Views)
I mean a batch file you would include in the installation kit as a support file, to be installed into the Install Directory.
Let's call it showreadme.bat. Then, in the "Advanced.." dialog of the App Builder, you simply specify showreadme.bat as the executable to be run, without parameters.
The batch will work if the installer launches it from the Install Directory (otherwise you may need to add a parameter to the batch command line, but I think it is worth to try the simplest case).
Paolo
Paolo
Message 5 of 12
(4,586 Views)
Hi again Paolo,
I tried your proposal, but I get a error message saying that the "readme.txt" is not found. The prompt has the following value:
C:\WINNT\system32>notepad readme.txt
and not the instalation path.
The readme and batch files are correctly created and work with no problem after installation, but I would like to make it as a pop up once the program is installed. I guess I should make use of the command argument "[INSTALLDIR]", but how to assign it in the bat file?
Thanks for your time
Mensaje editado por Gatet
Message 6 of 12
(4,574 Views)
Write in the bat the following line:
notepad %1readme.txt
and specify [INSTALLDIR] for the command line arguments.
This works for me.
Paolo
Paolo
Message 7 of 12
(4,565 Views)
Unfortunatelly, not for me yet...
My command prompt line shows now:
C:\WINNT\system32>notepad C:\Programreadme.txt
when it should be C:\WINNT\system32>notepad "C:\Program Files\Application\readme.txt". Could it be a problem of the space in the "Program_Files" folder?
I atatch u a screenshot of the installer settings to check that values are written as u indicated.
Message 8 of 12
(4,548 Views)
If you have spaces within the path, modify specific folder names with the following syntax C:\"Program Files"\....
ThSa
Message 9 of 12
(4,545 Views)
The problem is indeed in the interleaving space.
OK, let's do it in a different way: write only      notepad %1     in the bat
and specify     "[INSTALLDIR]readme.txt"     as argument (with the double quotation marks).
This works for me and supposedly for you too Smiley Wink
Paolo
Paolo
Message 10 of 12
(4,541 Views)
