creating a pulse train on serial port using labview 6.1
want to genrate a pulse to trigger AOm which needs a pulse of 1 msec duration i'm using rs232 port and labview6.1version
(3,484 Views)
Don't use the RS232 port. By design, it will send out a start bit, 7 or 8 data bits, and stop bit(s). You cannot change that. Therefore it is not ideal for sending out pulses of certain duration. Instead use the parallel port. Labview has examples on how to use the parallel port. You can also search NI website for examples. Just set one of the lines high, wait for 1msec, then set it low.
- tbob
Inventor of the WORM Global
(3,480 Views)
You can control the state of the DTR and RTS lines of an RS232 port in LabVIEW. The following KnowledgeBase shows how you can assert and unassert those lines.
KnowledgeBase 21P954LI: How Can I Control the DTR and RTS Serial Lines in LabVIEW?
Shawn B.
Use NI products on Linux? Come join the NI Linux Users Community
(3,463 Views)
shawn B
thank you
i could make the vi needed and hopefully helped other working on the same problem
thanks once again
best regards,
sridhar
(3,419 Views)
