creating a constant text string with tab separation
I would like to find out the Lab View string code for inserting delimiting tabs.  I am trying to create colum heading for data string.  I have looked in the syntax help, but have not found any reference to tabs.  I have also tried simply typing the tab key, but this does not work either.
I am quite sure the solution is very simple, but I have not been able to find it.
thank you
Alfonso
A. Lopez
(7,302 Views)
The code is \t and there is also a tab constant in the string palette.
___________________
Try to take over the world!
(7,286 Views)
@lopez wrote:
...  I have looked in the syntax help, but have not found any reference to tabs.  ...
Check in the online help for Backslash ('\') Codes Display  for a complete description of the options ... and make sure you switch the sting constant to '\' Code Display by right clicking.
Fading out. " ... J. Arthur Rank on gong."
(7,281 Views)
