create xnet LIN schedule
I am looking for an example, where a simple LIN scheduler (master) is configured and started. I have an LDF, so the VI schould run a schedule table of it:
- some frames should be sent with all the payload bytes
- on some of the frames only the ID should be sent, and the slave fills its payload in it
Can anybody provide a simple example? I haven't found any in the delivered XNET examlpes.
Thanks in advance.
(4,613 Views)
what speaks against the XNet Examples in the Examplefinder, e.g. LIN Frame Output Single Point.vi?
(4,571 Views)
that would be useful, but I don't have LIN Frame Output Single Point.vi in the example list.
Does LIN Signal Input Single Point.vi do that what I need?
Madottati
(4,565 Views)
I guess so, its basically the same just with input and fsignals, not output and frames. You should have the example i mean. Check the picture.
(4,560 Views)
so I tried it, it sends frames to LIN, but does not read. Should I create an additional parallel session to read frames from an ECU?
Another question: is there any function which gets all the data transfer (TX and also RX the same time) and returns them into an array of frame clusters? I mean the data, which physically appeared on the LIN bus.
Madottati
(4,510 Views)
