create tag's DSC module
I have a master MODBUS based on PIC microcontroller, i want to view your register on DSC module for create alarms and historial. i have create a server? other form do? how create a server? how define tag on server?
(2,981 Views)
Greetings Jacr,
It sounds like you are trying to create Tags to access a register using LabVIEW Datalogging and Supervisory Control.  If you are using LabVIEW DSC 7.1 then you might want to check out  the link below to the LabVIEW DSC Developers manual.  The process of creating DSC applications is discussed in detail.
LabVIEW Datalogging and Supervisory Control Module Developer Manual
https://www.ni.com/docs/en-US/bundle/321294f/resource/321294f.pdf
Please post a more detailed question of your application so I can better understand your question.
S. Bassett
(2,964 Views)
