create spreadshhet file from strip chart data
I have written a VI which displays a cluster of 4 data inputs on a strip chart.(4 traces)
I would like to send the same data to an excel spreadsheet but I can't get the data int a siutable format.
I then need a siutable VI for generating the spreadsheet file.
(2,694 Views)
I am assuming that your cluster is of 4 1-d arrays.  Based on that, you could unbunble the arrays, feed them into a Build Array, which should give you a 2 d array, and then use the Write to spreadsheet file vi in the File I/O pallete.  All of the lines of data will probably be "horizontal" in the file..  If you want it listed "vertical", you can use the Transpose 2 d Array in the Array pallete.
If this does not work, please provide some more information on the data and vi that you are using.
Kenny
(2,662 Views)
