create shortcut to word file
Is it possible to create a windows shortcut to a word document from my application?
I am creating a word document based on user input, and would also like to place a shortcut to that file elsewhere.
Message 1 of 15
(8,227 Views)
There is a solution suggested here, it requires downloading an exe though.
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
Message 2 of 15
(8,224 Views)
I got curious how to do it without an external exe.
Here you go... (see attached)
Message 3 of 15
(8,212 Views)
Troy - I'd like to take a look at your solution ... would you mind posting a version for those of us still back in 8.5?
Thanks.
Message 4 of 15
(8,178 Views)
Here ya go...
Message 5 of 15
(8,165 Views)
Hello everybody.
I have tried this example using windows 7, it does not work. A message says access denied. But you use windows xp, the example works perfectly.
I have administrator privileges. both windows 7 and windows xp
Message 6 of 15
(8,009 Views)
The defaults set in the vi were designed to work in Windows XP.
The location and working directory need to be changed for it to work in Windows 7.
Here is one with the defaults set to work in Windows 7...
Message 7 of 15
(7,996 Views)
Hello Troy.
Do you know the location and working directory to create shorcut for all users in windows 7?. There are users don't have admin priviliges.
Thanks a lot.
Message 8 of 15
(7,976 Views)
When I run the Create Shortcut.vi, when the shortcut is created, and I look at the Properties of the shortcut, there are double quotes (" ") around the Target name.  This shortcut points to an executable I am running.  The double quotes around the Target causes problems when I try to try to run the executable by doule clicking the shortcut - an error comes up.  If I go into the properties of the shortcut and remove the double quotes around the Target, and save, then when I double click the shortcut to run my executable, it runs just fine.
Any idea how/why the double quotes ends up in the Target field, and how do I make it so they don't appear when I run this Create Shortcut.vi?
Message 9 of 15
(7,333 Views)
The double quotes are automatically added by the ActiveX function when there is a space in the path.
If there is no space, there are no quotes.
Do you have a space in the filepath? Is the only space the one in the "C:\Program Files" part?
Try using %ProgramFiles% instead.
So           "C:\Program Files\MyApp\MyExe.exe"
becomes  %ProgramFiles%\MyApp\MyExe.exe
What I don't understand is why the quotes are creating an error. It always seems to work fine for me.
What is your full path? What error are you getting?
Message 10 of 15
(7,321 Views)
