create searching sub vi
Hi @all again,
it is possible to change the vi in this case, that the loop stops if there is a hit (i think it works) and a output which shows if there is a hit, or there is no hit(boolean).
But the loop stops if the array ends. Do you know. I'll use this vi as sub.vi with 5 Inputs and 1 array input and it should show me if there is a hit or no hit (output=boolean)
I Think it is easy but , if havn't found a goog solution.
Thanks All,
Thomas
(2,688 Views)
Hi all,
can nobody help me? Is there any not clear? I need your help!!!
Thanks Thomas
(2,666 Views)
If I understand correctly, all you have to do is put in an Array Size function and if the result is non-zero there's a match.
(2,660 Views)
Already answered here. 🙂
(2,651 Views)
