create own icons in LabView
Hello everybody,
I was just wondering if it’s possible to create my own icons. I’ve in LabView this heading Pipes, Pumps & Valves but I need more different of these icons.
I must build visual my whole trial schematic in LabView to describe my measurements so for example heating systems or burners.
It would be awesome if somebody could give me some advises on that.
Regards
Stiff Master
Message 1 of 9
(4,750 Views)
You have unlimited possibilities. For example:
  1. You can import custom graphics into the true and false states of a boolean button. You then can use it as control or indicator to show the desired state. Use the control editor.
  2. You can create a multistate picture indicator using a picture ring.
  3. You can import any background graphic to your front panel
  4. etc.
Is that what you need?
Message Edited by altenbach on 08-09-2005 02:13 PM
Message 2 of 9
(4,747 Views)
You say you have Valves & Pumps. This most likely means you have the DSC module installed.
If you do, you should also have the Image Navigator (Tools>>DSC Module) which has many images, including heating related.
You should just be aware that LV isn't terribly good when it comes to dynamic graphics. If you only to place the images once it should work fine, but for changing systems you may find you will need a lot of work.
___________________
Try to take over the world!
Message 3 of 9
(4,713 Views)
Good day Altenbach and TST,
Thanks for your quick replay. That is exactly what I’m after!
I hadn’t had time yet to read Control Indicator pdf but I recon that is the perfect answer for my question.
And TST, I must be honest; I’m fairly new with LabView so I’ve no idea what this DSC Module is. I’ve under (controls/DSC Server Data Types) something with DSC. Is this what you mean? But I can’t find an Image navigator.
Is this DSC something different or this that what you mean?
Anyway, many thanks so far!
Cheers
Message 4 of 9
(4,678 Views)
DSC is the the Datalogging and Supervisory Control module. It deals with industrial automation and such.
If you have the image navigator installed, you should find in under the Tools menu, not in the controls palette.
I'm not sure whether what you saw is part of the DSC module, but I don't know of any other DSC and the controls with the pumps and valves graphics are installed with the DSC module.
___________________
Message 5 of 9
(4,672 Views)
Yes, you are right!!! Now I found it and there exactly that icons which I need.
Perfect, thanks you very much for your efforts and your phenomenal quick replay!
stiff
Message 6 of 9
(4,666 Views)
I was just having fun with my programs and did find the way to past a picture into the front panel but I can't figure out how to make it in the backgroud so that my front panel object appear on top of it.  It must be some simple setting that I can't find and just wondered if anyone might know how to do this before I spend an hour or so going around in circles!
Message 7 of 9
(4,366 Views)
In the middle of the toolbar are four buttons. The rightmost allows you to set the Z-order, so just select your decoration and then move it to the back.
___________________
Message 8 of 9
(4,363 Views)
You guys are sooooo great.  I knew it was something simple that I just hadn't used before.  Felt kind of stupid asking, but I do appreciate the help and now I can make some really cool looking VI's!!!!
Smiley Wink
Peggy
Message 9 of 9
(4,358 Views)
