create installer for creating a palette
My query is to create a installer (setup.exe) file  so that if i install the file then it will create a function palette (of my custom vis) in labview auitomatically.
Like in the link below modbus installer is there: when installed it creates a palette in the user libraries.
http://digital.ni.com/public.nsf/allkb/47F898161792C62F8625756A005D0E7E.
I have gone to through the link below but it gives idea about adding, editing or deleting palette manually.
https://decibel.ni.com/content/docs/DOC-8742
Shrenik
(3,485 Views)
Hello shrekt,
You can use VIPM to build this!!!!
Rodéric L
Certified LabVIEW Architect
(3,483 Views)
All that you really have to do is create the palette yourself and then include the .mnu files with the rest of your files. As far as I know, that is what the modbus example you mention does.
(3,471 Views)
vipm does work , but it does not create a seperate installer,
@Dennis: I will try that out.
Shrek
(3,457 Views)
Dear shrekt
I am also trying to do this with out VIPM. Is it possible without VIPM or not? I am using LabVIEW 2010.
regards
(3,419 Views)
As I already mentioned, you do not need vipm. You simply create the palette and install the mnu files. Instructions for creating a custom palette are given in the first post.
(3,408 Views)
Dear
Thanx a lot sir i have created the costum palette.
regards
(3,385 Views)
