create image (PNG) of the Data of CSV file
Hello All
I want in one plot (image png ) plot  the data of CSV file separately  and then save this image to call it after by teststand . please can some one help me
advance thank you for your support
Best regards
Message 1 of 8
(5,123 Views)
hi ab31,
you could plot your .csv data with a graph, and then get the image via an invoke node.
http://digital.ni.com/public.nsf/allkb/5AE4ADCBB65A6D8F86256FBF007A1AC1
how to -anything- with teststand, i don't know.
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 2 of 8
(5,095 Views)
@Ab31 wrote:
[...] save this image to call it after by teststand . [...]
That makes no sense as TestStand cannot work with image files.
I assume that you want to store the image in a report. If so, pass the array to TS and use the array report configuration to insert a graph image in the report.
Norbert
Expert: Geometry
Message 3 of 8
(5,093 Views)
Hello
thank you for your feedback I will try it and I will let you Know
Best regards'
Habib
Message 4 of 8
(5,082 Views)
Hello
Yes Indeed its for the report ,
Best regards
Message 5 of 8
(5,080 Views)
Use a VI to load the CSV and pass the data to TS.
Depending on the size of the file, reduce the data before passing it.
EDIT: I hope you are familiar with TS as such that you pass the data as measurement value. Otherwise, the shown screenshot above will not have the result you are looking for.
Norbert
Expert: Geometry
Message 6 of 8
(5,076 Views)
No I never use the TS , in the past I used teststand just to do some manuel test
plese can you give me details about the way that I have to do
advance thank you
Best regards
Message 7 of 8
(5,068 Views)
Please review the example "Displaying Graphs in a Report" which is part of the TS installation. It should answer your question.
Norbert
Expert: Geometry
Message 8 of 8
(5,056 Views)
