create chessboxes
Dear all,
I am working on an application where i have to show different designs of chessboxes to the user. The user can select a particular design of the chessboxes and i want to display that selected desing on the screen.
The chessboxes on the screen change their color from black to white and vice versa after 1 second.
I have created a VI which will change the color of the chessboxes, but i am finding trouble about how to create different desings and showing them to the user.
I am attacing 2 files here.
1) The image file showing different design patters that i want to show to the user.
2) VI which will change the colour alternatively.
Please suggest me a solution of how can i create different desing patterns and how can i present them to the user.
Ritesh
(4,048 Views)
Hi Ritesh,
i'm not really sure what you mean, but why don't you use a 2d array in the "checkers.vi". What else do you need to change?
Mike
(4,019 Views)
Hi Mike,
If you ran the VI, you could see 64 boxes changing from black to white and vice versa.
I want the user to select a particular pattern from a Window which will display all the patterns available. In the JPG image, i place 4 different patterns that could be shown to the user.
I just want to know how can i display all the patterns to the user so that he can select a particular pattern and according to the patterns, the boxes will be shown on the screen?
I think "Pict Ring" will solve the purpose but i am not getting how to customize that control to show all the pics that i want to show.
you mentioned about 2-D array.
How will that be useful ?
Ritesh
(4,002 Views)
Hi Ritesh
If you use the clasic simple boolean flat square button as a 3d array and use property nodes to change the colours I think you can get what you need. Take a look at the attached vi.
Hope this helps
Ian
(3,970 Views)
Accepted by topic author LVCoder
There is an example of using a picture control to create a chess board in the Developer Zone
(3,956 Views)
Dear all,
Thanks for your valuable comments.
At last i got some suceess.
And as i said Picture control was the way to go. Though i the task has been done, but i ma still not sure is there's a better way to do the same.
I am attaching my VI here. Pls have a look at it and let me know if i could do it in a more efficient way.
I am changing the design pattern by changing the index of a 2-D array on the front panel.
Ritesh
(3,911 Views)
