create checksum from c language
I want to control a polycold by RS 232 via Lab view.
In the manual I found the code for determining the checksum. When I try this, i get other checksum values. I have a bit of c language attached as well and the description from the manual.
Who can help me and understand what the checksum has to be.
(3,455 Views)
A checksum is never just a simple sum...
Does this match up with what is expected?
(3,431 Views)
I tried your advise, but I still did not get the correct checksum.
In the mean time I found two commands I can give, with the correct checksums (2 and 4). See attachments.
I also made a screen shot of docklight (I use this program to test the rs 232 serial commands). When I know how the commands works, I program them in lv.
(3,416 Views)
Accepted by topic author RvG
This seems to work:
A really big hint is that when you are sending '0' or '2' or '4' to the instrument you are sending the ascii values, not literal values.  A second hint is having a few ascii -> character mappings in your head (such as 0,a,A) is often useful.
(3,402 Views)
Are you following the directions in the text attachment from your first post? It looks like the checksum should ignore the $ character that begins the response, but it's not clear if you're removing the leading $ before calculating the checksum.
(3,394 Views)
