create array
Hi all ..
I want to create array 4*2 ( 4 rows , 2 column)  , can any one help me with this
thanks
(4,552 Views)
Hi elyan,
you have following capabilities:
  • take an array constant and select "add dimension" (you can resize it with the mouse)
  • take initialize array (this block is sizeable, too)
see the picture
Mike
(4,549 Views)
I cannot understand how this pink matrix appears in the block diagram. (Copy/paste from the examples we tested it's not working properly. I must do myself your circuit for 3 combo boxes)
(4,411 Views)
Hi treadagon,
if you mean how to create an array constant, then go to the array section and select an empty array. Insert a constant of the data type you want into it and you have your array. With right click on it you can add or remove a dimension.
Hope it helps.
Mike
(4,408 Views)
Array section? You mean in the functions palette? I didn't find nothing there. How can I select an empty array?
(4,403 Views)
Hi treadagon,
yes. See the attached picture!
Mike
(4,398 Views)
Hi Elyan,
Here's are some very useful getting started FREE courses on LabVIEW.
It's several hours long, but it will save you even more hours in the long run.
Please check it out.
Thank you
Van L
NI Applications Engineer
(4,345 Views)
