create an executable using tag engine
it's impossible to execute an .exe using tag engine with a computer were labview DSC module is not install.
please help me,i want to create an .exe wich is possible to execute on all computer explain me the process to create this.
what are the files to be added to permit that???
thanks for your request.
(3,477 Views)
hi
as far as i know it is not possible to execute an exe which calls the tag-engine without the engine installed on the machine. you also need a DSC-licence on each machine you want to use DSC. you can't add DSC to the installer of your exe, sorry!
best regards
chris
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(3,462 Views)
Hello Julien,
As explained in the tutorials linked below, there is 2 methods for distributing applications created with LabVIEW DSC module.
* Distributing Applications Created with the LabVIEW DSC Module
http://zone.ni.com/devzone/conceptd.nsf/2d17d611efb58b22862567a9006ffe76/d2cc543dc86e41b886256a6c005bdd98?OpenDocument
* Building Applications Created with the LabVIEW DSC Module
http://zone.ni.com/devzone/devzoneweb.nsf/Opendoc?openagent&57034D4A0F82844286256A1C006AC454
* Datalogging and Supervisory Control Module
http://digital.ni.com/softlib.nsf/webcategories/85256410006C055586256BBB002C0CF1?opendocument&node=132070_US
Hope this helps.
Best regards.
Matthieu Gourssies
National Instruments France
(3,441 Views)
thanks all.
(3,429 Views)
