create a ramp like function in Formula node
Hi all,
I need to create a ramp like function in Formula node which will be repeated every second. This is what I tried:
if (t==0)
y=0.1;
else if (t>0 && t<0.3)
y=t+0.1;
else if (t>=0.3 && t<0.4)
y=0.4;
else if (t>=0.4 && t<0.7)
y=-t+0.8;
else if (t>=0.7 && t<=1)
y=0.1;
It shows the correct profile for one cycle,. but I need it to be repeated after each second. I belive it should be done in a for loop structure but since I am a NI newbie, not sure how.
Any help is appreacited.
Navid
Message 1 of 16
(3,742 Views)
No need for any formula node. Just use graphical primitives. 😄
Message 2 of 16
(3,721 Views)
Thanks. It is going to have other parts to cycle synchronoise (phase lock) it with other equipment (laser, camera, sensors). The way the code is written so far (for other profiles) is based on Formula node. That is why I need to implement this into formula node.
Message 3 of 16
(3,711 Views)
Once you have your function output you have your function output.  It doesn't matter how you get it.  So, get it the easy way.
Each section you describe is a simple waveform section
if (t==0)
y=0.1;
y=t+0.1;
Ramp pattern start 0.1, end 0.3 samples, TBD you didn't specify a dT
y=0.4;
Initialize Array value 0.4 size TBD you didn't specify a dT
y=-t+0.8;
Ramp Pattern start 1.2 end 1.5 size TBD you didn't specify a dT
y=0.1;
Initialize Array Value 0.1 Size TBD. (that dT again)
Concatenate them together in a single Array or better yet use a Waveform Datatype.  No ifs no ands no "but if onlys" and you can even test, adjust and add notes for each part.
"Should be" isn't "Is" -Jay
Message 4 of 16
(3,679 Views)
Thansk for your reply. This is how it looks like at the moment:
dt is 10 ms. I need the profile to be repeated after each cycle. But with the way I wrote, it is only one cycle.
Navid
Message 5 of 16
(3,667 Views)
Hi Navid,
Yes, the way you wrote your code it will execute once. (Atleast what we can see from your images: you know we cannot edit/run/debug images in LabVIEW!?)
You also wrote:
Right now your t will go from 0.00 to 24.99: how does it fit to your "repeat every second" requirement???
if (t==0)
  y=0.1;
  y=t+0.1;
This is Rube-Goldberg: there's no need for the "t==0" case…
Message 6 of 16
(3,640 Views)
Thanks for your response.
I changed the loop count to 100. Now it looks like it can generate the second cycle immidiately after the first one and so on. Is that correcT? I attached the code as well.
Thanks again,
Navid
Message 7 of 16
(3,631 Views)
Hi Navid,
I prefer LabVIEW2019: please use File->Save for previous and reattach your VI.
Message 8 of 16
(3,619 Views)
Sure, attached is the 2019 version.
Navid
Message 9 of 16
(3,611 Views)
Hi Navid,
why is your code so large and does not follow the style guide?
See this:
I don't think your "length" calculation is correct, but it is up to you to judge this as only you know the requirements!
Message 10 of 16
(3,605 Views)
