create FFT size
this is the data file which the spreadsheet reads.
Message 11 of 16
(1,319 Views)
Hi altenbach,Thanks for replying.
i wonder if you understand wat i was trying to do over here...
Suppose i got 4 input signals i used only two of them to calculate the coherent functionSmiley Indifferent.
Message 12 of 16
(1,298 Views)
Hi Altenbach,
i have problem in using the power spectrum and cross power spectrum. Can you help me?
Message 13 of 16
(1,284 Views)
Sorry, I have no idea what you are trying to do here. What kind of problems are you having?
You should say what the problem is! (e.g.: (1) My program crashes, (2) the result is wrong, (3) I don't understand the theory, (4) etc.)) 😉
What kind of data is this? What are you trying to measure?
Message 14 of 16
(1,282 Views)
ok these datas contain 4 columns of sampled data. I am trying to measure the mulit-coherence between these signals.
i need PSD and CSD as building blocks to build the coherence but the problem i am facing is i have no idea how to create the CSD from the FFT cross power.vi. mainly because i have no idea how the values of the PSD came about from the FFT power spectrum.vi
or do you have any suggestions in buliding the PSD from the FFT power spectrum vi other then using PSD.vi
(How do i attached multiple vi in an attachment?)
Message 15 of 16
(1,280 Views)
Hi celynn,
There is a tutorial on The Fundamentals of FFT-Based Signal Analysis and Measurement in LabVIEW and LabWindows/CVI which I think you will find very helpful.  You can read the tutorial here: http://zone.ni.com/devzone/conceptd.nsf/2d17d611efb58b22862567a9006ffe76/c045a890751303a686256865006....  Take a look at it and let us know if you have further questions.
Good luck!
Megan B.
Message 16 of 16
(1,252 Views)
