create EXE in Labview8.0
how can i create exe in labview8.0  or, if i can convert labview 7.1 program in to labview8.0 then it can be done esily using the option from TOOL >> Build Applicaiton,,,
so, is there any way to do so,,,plz.. msg
manisha
(2,932 Views)
In LV 8.0  you have to create a build script under "Build specifications" in the tree of you LV project.
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,931 Views)
no,, no i could not get you exactly,,in Project Option the BUILD option is dissabled,,,
manisha
(2,927 Views)
You can not build, what is not selected.
You first have to create a build script. Right-click "Build specifications" and then select New > Application (exe). If you've done this, the build script can be executed (built) by either right-clicking it and selecting "build" or by browsing the menu.
Have a look at the picture.
Message Edited by becktho on 03-16-200608:49 AM
Using LV8.0
(2,926 Views)
