crc8
 I use labview8.5, and I would like to make a program to calculate the CRC8.
Can you help me please
cordially
manu23
Message 1 of 17
(7,806 Views)
Hi manu,
search the forum, CRC calculations are rather common in here!
Message 2 of 17
(7,801 Views)
Did you search the forums for crc8?  If you had you might have found this .
Message 3 of 17
(7,795 Views)
And please don't duplicate you post, or at least say so if you do.
Epictetus
Antoine Chalons
Message 4 of 17
(7,792 Views)
Yes I looked, but I can not open it because I do not have the right version of labview
Message 5 of 17
(7,789 Views)
Hi manu,
then you should post in the "Version conversion" board!
Message 6 of 17
(7,784 Views)
Then you can ask for someone to "save for previsou version" there is a section for that. Post a link to the VI you would like to be down-converted and the LV version you have 😉
Epictetus
Antoine Chalons
Message 7 of 17
(7,782 Views)
I duplicate my post, because the english forum is more reactive
Message 8 of 17
(7,779 Views)
OK, that's a good reason, but next time give the link to the orginal post in the new one.
Epictetus
Antoine Chalons
Message 9 of 17
(7,776 Views)
Out of curiosity why are you using a CRC8? It is a very weak CRC and you have a 1 in 255 chance of not detecting an error because multiple bit patterns will result in the same CRC. Even a CRC16 is fairly weak.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 10 of 17
(7,754 Views)
