counting .png files in subfolders
I have to search a folder and his subfolders for .png data(only in subfolder are files), when I find a png file I have to write the number of them in an array(for every folder one).
But somehow I am a bit lost here, can someone help me?
(3,926 Views)
Hi NoName,
where are you lost? What is your problem?
Comments:
- There's a function/VI in the file palette that determines the file suffix (like "png"), no need to do that "manually"
- Learn about using shift registers!
- You don't need that inner while loop!
- Please post a VI instead of an image. We cannot debug images…
(3,917 Views)
here is a test VI with an example Folder and subfolder
the Result in the Array needs to be: 9  3  5
(3,907 Views)
Accepted by topic author NoName1771
Hi NoName,
solution without using a shift registers:
You still should learn LabVIEW basics…
(3,896 Views)
Thank you, yeah I am still in training, so shame on me Smiley Wink
(3,880 Views)
A lot of this can also be simplified to a single VI:
This does a recursive directory listing and returns all .png files in the directory - it also returns a count of the files amongst other things - you may find it easier to call this in each directory (as you want the number of files in each directory, rather than the overall number of files in total).
(blog)
(3,872 Views)
Sam is right: replace the inner FOR loop (including ListFolder and Sum) with RecursiveFileList…
(3,866 Views)
