counters gating
I would like to generate two sets of pulse trains with my available counters (2): CTR0 is finite of about 50 pulses at 100Hz 80% duty cycle and CTR1 is continuous 40KHz and 50% duty cycle.  I would like to internally connect the output of CTR0 to the gate of CTR1.  The net effect is that I would get a 40KHz 50% signal for about 8ms and off for 2ms, repeat for 50 pulses.
After a couple hours of googling I found out that this not possible because labview use both counters to generate a finite pulse train.
Is this a show stopper?  Is there someway to do what I described above in labview?
I am using labview 8.5 with PCI6221 card.
Thanks in advance
hv
(2,991 Views)
Hi HV,
The card that you are using is an M Series DAQ card. When you generate a finite pulse train, two counters are used. One counter is used to generate pulses, and the other is used as a gate.
Best Regards,
Jignesh
Best Regards,
Jignesh Patel
Principal RF Software Engineer
(2,969 Views)
Hi HV,
I would like to add a few things to my previous post. There is a way to do what you want to do with the PCI-6221. The approach you need to take will be a little different. Take a look at:
Creating a Delayed, Retriggerable and Finite Pulse Generator
Using One Counter to Generate a Retriggerable Finite Digital Pulse Train with a PCI-6602 and DAQmx
Retrigger and Repeat Finite Digital Pulse Train in LabVIEW
Let me know if you have any questions for me.
Best Regards,
Jignesh
Best Regards,
Jignesh Patel
(2,945 Views)
