counter
I'm new to labview and need to create an event counter, which works from an analog signal input, increments when a set value is reached and produces a warning message when a different, higher value is reached. I need the counter to increment only once when that value is reached, and to only increment again after the signal has fallen below the set value (at the moment my program counts continuously at sample rate once that value is reached). Any help would be appreciated.
(3,112 Views)
Show me the money - errr - code!  😉
Bill
CLD
(Mid-Level minion.)
(3,108 Views)
go to examples in labview for event trig
hi ?Q>
(3,060 Views)
So far this is it, and so far it's not doing what I want it to...
(3,040 Views)
  • You are incrementing the actual signal instead of a counter.
  • Your "false" case is not wired across.
  • Your shift register is not connected to anything
  • Your case selector is not wired.
(3,034 Views)
