counter function : How works the Set attribute function
I use Labview and a 6713 DAQ
I want to use the "set attribute vi" but I don't exactly what means the "attribute value number" and the attribute value type" in that vi
>Where can I find some data about that?
>What is the relation between the internal clock frequency and the attribute value number if I generate a pulse train ?
>How can I configure the frequency of my DAQ ? ( I can use 20MHz or 100KHz )
Any help is greatly appreciated
Renaud
(3,396 Views)
Renaud,
You can read the on-line help for the Set Attribute VI by right-clicking over the VI and selecting "Help." The help will describe each of those parameters. In addition, you can search through counter examples for your 6713 by selecting from the menu bar Help>>Search Examples>>I/O Interfaces>>Counters. Any example that demonstrates the functionality of the DAQ-STC counter will work for your board. In addition, you will find examples on pulse train generation.
Hope this helps.
Erin
(3,396 Views)
