count numbers in table
hi
im beginner in labview
i Extracts  the pixels from  part of an image into a  2D array
and i want to count number between 80 and 125 but i can't understand  how
so someone tel me how i can do this
thx for help
(3,865 Views)
Maybe something like this?
(if you expect a large number, insert a to-I32 before taking the sum.)
(3,854 Views)
hanks
i will try to do this
because my object is to  calculate the percentage of pixel in image like the function in NI vision builder 'count pixels) but in labview they don't have function to do this .
so i transforme the image To2D array.and count numbers between min and max and finaly calculate the percentage
(3,844 Views)
The total number of elements is just the product of the two dimension sizes, so calcuating the percentage is very simple.
(3,838 Views)
thanks
i will try to do
and if you cant send me this vi because i don't know the name of all the function in your image
I student is the first time I am working with labview
(3,828 Views)
As a student, this is a good opportunity to learn:
The functions are:
  • In range and coerce
  • Boolean to (0,1)
  • To I32
  • Add array elements
  • Multiply
  • Divide
  • Array size
  • Multiply Array Elements
Use "quickdrop" and start typing these words to get each function. If you don't know what quickdrop is, do a search. 😧
Good luck!
(3,796 Views)
thanks for your help Smiley Wink
(3,784 Views)
