could not acquire two analog signals simultaneously
I have a setup driven by a sawtooth wave of very low frequency (0.005 Hz). This is to ramp an electromagnet up and down. This is my primary siganl and the other signal is a pure dc voltage signal taken from from 4-point-probe measurement. I connected the first siganl the analog input (port AI0) of a USB DAQ (NI 6341) and the other siganl to port AI1 in the same DAQ. The code was giving an error 50103 but I moved the error notifier out of the while-loop and this helps.
Howerver, the code is not working properly and I need help to acquire the two signals and plot them in an XYgraph. The code is attached with this message.
Thank you
Hadi
(2,771 Views)
Your code makes no sense. Create a task with both channels and one single read operation. You are reading Nchan, 1 sample where N-1 for each train. If you want to read both samples, N=2 and the array contains a single reading form each channel, one for X and one for Y. Convert that to a single complex scalar and build it up into an array of data in a shift register. You can connect the complex array directly to the xy graph terminal.
Don't clear the task at each iteration (Why would you do that???).
(2,742 Views)
Hello Altenbach
Thank you so much for your comments. I tried to alter my code and here it is attached with my reply. The code is working without error but with no display or progression for the XY plot. I don't know about how to implement shift registers correctly. Therefore I need some help or guidance to do that.
Thank you
Hadi
(2,668 Views)
Ouch.  That is actually worse.  I don't know which of Altenbach's comments you actually tried.
Two channels.  One task.  See below.  A better concept would be to set up continuous sample and acquire multiple samples at the rate the card is set for.
(2,659 Views)
Thanks. How do you combine two-channel inputs in the same task? I tried but I couldn't.
(2,644 Views)
Click the drop down on the constant.  Click Browse....    You get a dialog where you can select multiple channels.  (use Control and Shift as necessary.)
(2,632 Views)
