corrupted serial data when reading
thank you billko
how can i limit the amount of information being showed in the indicator?
Message 11 of 17
(779 Views)
@moreins1 wrote:
thank you billko
Cross has a better solution.
Bill
CLD
(Mid-Level minion.)
Message 12 of 17
(775 Views)
Here's a quick example of what I mean.  It is far from complete or fully functioning for what you need.  It is an example.  You will have to format your data however you want before writing it to file.
Message 13 of 17
(767 Views)
hi
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 14 of 17
(741 Views)
@Ranjeet_Singh wrote:
hi
No.  You don't want to keep opening an closing the serial port!  All you do when you do that is waste resources and put things in funky modes.  Open/setup once during program bootup, read as much as you want repeatedly in main loop, close once during program shutdown.
Message 15 of 17
(738 Views)
The image proves what I said. LabVIEW is a dataflow language so the close will only happen when the loop stops - exactly what should be done.
Fixed delays are often a lazy way to program. They also can result in buffer over runs as well since you do not read fast enough. Believe me, written carefully and with an understanding of the instrument, you don't need them.
Message 16 of 17
(735 Views)
True enough.  I can think of only ONE instance (out of countless times) when a careful understanding of the communication needs of the equipment was achieved, that I could NOT eliminate hard-coded waits - and that was a power supply that was so dumb, the programming instructions specifically said "The average command processing time of the ZUP Series is 15mSec. It is not recommended to send strings of commands to the ZUP power supply without considering the processing time."  In other words, hard-code a wait of at least 15 ms in between commands.
Bill
CLD
(Mid-Level minion.)
Message 17 of 17
(720 Views)
