corrupted llb
An error occured while listing the contents of C:\...\library_name.llb. I have to extract some vi's or to repair this library. In order that I will be able to do this I need a document with full details of llb file format internal structure.
Any advice and help will be appreciated. Thanks in advance for this courtesy.
zeevro
(2,928 Views)
You can try the uncorrupt tool at http://forums.ni.com/ni/board/message?board.id=170&message.id=220604&query.id=114695#M220604.
You really shouldn't be using an llb. The only reason the llb is still around is for ease of source code distribution but it is a really bad way to save files in development. And, as I'm sure you already realize, doing frequent backups is also a must.
(2,925 Views)
Hi Dennis.
Thank you for your valuable suggestions and advice (for future).
Unfortunately I had bad luck. The decorruptor did not give me any help.
Thanks again.
zeevro
(2,886 Views)
