copying program to another computer
My team has developed and deployed a program for our FRC robot, and it works as advertised when deployed from a Vista OS.  We have update 3 installed, and the cRIO has been re-imaged.  When the program was copied onto a XP computer, it would not deploy to the robot--we received the 'FPGA bitfile version not recognized' error.  The same program still runs from the original computer, but not the new computer.  What needs to be done to make it work on the new computer?
(3,321 Views)
Are you running the code or executable. If code, do you have the same LabVIEW version installed in  both PCs?
"A VI inside a Class is worth hundreds in the bush"
യവന്‍ പുലിയാണു കേട്ടാ!!!
(3,294 Views)
You will most likely find much better help with this issue in the forums at www.ni.com/first .  There is also a phone number listed there that can be used for phone support.
(3,263 Views)
Do you have update 3 installed on the XP computer as well?
(3,243 Views)
