copy to clip board
I've tried to copy a graph to clip board by using EXPORT IMAGE Property node.But when i pasted it on a word document i got a black & white image without border like the one here in attachmement.How to get the colour image Programatically (not through short cut menu)?
(2,967 Views)
If you don't mind a Windows only solution (which I assume you don't), you can try using the VIs we used in the Code Capture Tool, which allow copying a bitmap to the clipboard.
If you want to insert the image into a Word document, you might also try using Word's object hierarchy. There should probably be some examples in the example finder (Help>>Find Examples) and it's possible that the report generation toolkit already allows you to do this.
___________________
Try to take over the world!
(2,946 Views)
Hi Swathi,
There is an example  that shows you how to print certain front panel objects in color.
Hope this helps!
Warm regards,
Karunya R
(2,922 Views)
