copy/paste at higher resolution?
When I copy an XYGraph with Invoke Node: Export Image, setting the format to PICT or EPS, the plot is dumped into the clipboard or a file with the limited resolution of the screen (72 DPI). This problem seems to be specific for the Mac platform, for which EMF format is not supported. How can I copy a graph as vector graphic with printer resolution (300DPI)?
Ivan
(2,823 Views)
Sorry, I am not familiar with anything specifically Mac, by you could probably plot it to a second (hidden) subVI with a graph size much bigger than the window and programmatically export from there. Maybe somebody has a better solution?
(2,805 Views)
but then cursor text will be very small compared to plot
+ user will have to shrink after paste...
a better solution?
(2,795 Views)
