copy last structure with button
Hello!
How can I make that button which can copy/paste last structure?
So I have a structure with some options and some event(It is a "panel"). But I want more options and I want nex panel. And I would like do it with button.
I don't know how can I mak such button.
Thank you!
Gabor
Message 1 of 8
(4,975 Views)
Hi Bagor,
sounds like you want to learn some LabVIEW basics (like calling subVIs and showing their front panel): I recommend to take the free online learning resouces offered by NI!
- What kind of "structure" are you talking about?
- You will find a lot of buttons in the front panel element palette.
Message 2 of 8
(4,968 Views)
Hi GerdW
There is a panel/chart where 10 dresses are set, and in each dress is 6 dispersion. These dispersions are switchable. I'd like to make these panels copied with a keypress, to make an infinite number of variations.
Message 3 of 8
(4,943 Views)
dress? You mean PLOT?
dispersion? I get confused.....
Switchable dispersion? More confusion....
Maybe an example of WHAT you want to copy helps...
Norbert
Norbert
Expert: Geometry
Message 4 of 8
(4,940 Views)
So I don't make it, because I'm stucked at this concept.
Ar R1 R2 R3 L1 L2 L3 are each global variables that runs a LED device? If anybody could make it or help in making it i would be gratefull. I'd even pay for it.
Message 5 of 8
(4,921 Views)
Nice sketch, but sadly not really helpful.
Should that be a front panel layout?
Is there code you already connect to the first "setup"?
When you talk about "global variable": What does that exactly mean?
Norbert
Norbert
Expert: Geometry
Message 6 of 8
(4,911 Views)
Norbert you are from Hungary?
Yes I'd like to use this layout on the fornt panel. Unfortunatelly there isn't a code yet, because i don't have any idea of the solution. Global varaiable would be a pop up menu to operate the LEDs. There would be a filne named Global where the operational structure is saved. This is where I would select the lighting part.
Message 7 of 8
(4,899 Views)
Honestly, this sound more like a custom control.
An XControl would be a possible answer, but it sounds that this is out of reach for your current LV knowledge (unless you pay a partner to create one).
What is the exact purpose of duplicating the "person"? How often do you intent to copy it at maximum?
Norbert
EDIT: No, i'm not from Hungary
Norbert
Expert: Geometry
Message 8 of 8
(4,892 Views)
