copy and transfer a text file
hi need help
let say the 1st time it open it should b in default folder
later the user choose the path and close it
the next time the user run it , it should b show the path the user choosen
not the default path
hoe to do this........
Message 11 of 19
(1,210 Views)
Hi jeyanthi,
here is an example for you.
Hope it helps.
Mike
Message 12 of 19
(1,190 Views)
i attach the vi with tis i dono how to run as default as 1st load and stored the values 2nd time run
Message 13 of 19
(1,188 Views)
i try to write it to text file but i dont want to save in the text file..
Message 14 of 19
(1,187 Views)
Hi jeyanthi,
use your while loop with shift registers to store values. Why do you connect a timeout, if you don´t have any code in the timeout case?
How shall your program run? You can use more events.
Can you explain what you try to to?
Mike
Message Edited by MikeS81 on 05-28-2008 08:49 AM
Message 15 of 19
(1,181 Views)
im sry ... i also confused edy
this method my senior teached me b4
actually i have to read the text file frm default folder and pass to the dest select by user..
wen the second time the user open .exe the choose the text file is must b the one the user choose before and so do the destination path.
plz help
thk u
Message Edited by jeyanthi on 05-28-2008 02:14 AM
Message 16 of 19
(1,176 Views)
Hi jeyanthi,
in this case you can read the ini file, which exists beside the executable. At the first time you write your default path in. If your program run you can first read the pathes, then copy your file, and after that update the pathes in the ini file.
Mike
Message 17 of 19
(1,166 Views)
hi Mike sry i cant get it..
pls explain me how can i do tht
Message 18 of 19
(1,164 Views)
Hi jeyanthi,
here is a start how you can do it. You have to insert the read and write function.
Hope it helps.
Mike
Message 19 of 19
(1,141 Views)
