convolution for existing wav file
i have some dry-source wav files and some impluse response files for convolution.
they all made by the common recording program.
i need insert them to labview  for  convolution but  i could do it correctly  in opening them(use open waveform from file,or input wav). It will show the different data type from  convolution needed. If i should do some transform or the other way to insert the files ?
Message 1 of 1
(2,347 Views)
